Eviews 8 64b Can't Print Error "Out of Memory"
Posted: Wed Sep 04, 2013 2:19 pm
by kjd31
Hi there,
Whenever I try and print anything in EViews 8 64 bit it returns an error "Eviews8_64 Out of Memory." I used to be able to print from within EViews, and can print fine otherwise in other applications so it is not my printer... how do I fix this??
Thank you in advance.
Re: Eviews 8 64b Can't Print Error "Out of Memory"
Posted: Wed Sep 04, 2013 3:00 pm
What is your build date?
(Help->About EViews)
Posted: Thu Sep 05, 2013 5:41 am
by kjd31
"Enterprise Edition - August 27, 2013 build"
What should I do? Thanks
Posted: Thu Sep 05, 2013 9:03 am
by EViews Jason
How many printers do you have available to print from? Does the error only occur with a specific printer? If so, what type of printer is it?
Also send an email to
support@eviews.com with a reference to this thread. This way we can send you instructions to help us debug the issue.
Posted: Thu Sep 05, 2013 9:29 am
by kjd31
No, there are several printers to print from. None of which work
Posted: Thu Oct 10, 2013 7:39 am
by EViews Jason
The October 8th patch contains fixes which should fix the printer error. If you could kindly confirm the problem has been resolved, it would be appreciated.
