Hi there,
Whenever I try and print anything in EViews 8 64 bit it returns an error "Eviews8_64 Out of Memory." I used to be able to print from within EViews, and can print fine otherwise in other applications so it is not my printer... how do I fix this??
Thank you in advance.
Eviews 8 64b Can't Print Error "Out of Memory"
Re: Eviews 8 64b Can't Print Error "Out of Memory"
What is your build date?
(Help->About EViews)
"Enterprise Edition - August 27, 2013 build"
What should I do? Thanks
How many printers do you have available to print from? Does the error only occur with a specific printer? If so, what type of printer is it?
Also send an email to support@eviews.com with a reference to this thread. This way we can send you instructions to help us debug the issue.
No, there are several printers to print from. None of which work
The October 8th patch contains fixes which should fix the printer error. If you could kindly confirm the problem has been resolved, it would be appreciated.
