Bootstrapping in eviews 7
hamna
Postby hamna » Wed Aug 21, 2013 4:33 am
Can anybody help in understanding bootstrapping in eviews 7, I have to find the optimal debt level through bootstrapping in eviews by using panel data. What are the steps involved? Kindly help out immediatly.
regards,
Aisha Ismail
Re: Bootstrapping in eviews 7
Postby EViews Gareth » Wed Aug 21, 2013 8:24 am
Could you provide more details as to what you're trying to do exactly?
hamna
Postby hamna » Thu Aug 22, 2013 2:31 am
I want to determine the impact of leverage on firm value and to find out the optimal debt ratio for non-financial sector(including 150 companies for 6 years 2007-2012). panel data has to be used in analysis. Now to find out threshold value of debt, bootstrapping is required as per base article used in my study. Threshold autoregressive model is used but i am unable to understand how it will work in e-view, from where to start and what are the steps involved in this process. For more details, i can send the article that is to be followed in my study (methodology of the article), if required.
regards
Postby EViews Gareth » Thu Aug 22, 2013 11:27 am
EViews does not have threshold autoregression built in.
hamna
Postby hamna » Thu Aug 22, 2013 10:08 pm
which software i should use for this purpose?
hamna
Postby hamna » Mon Aug 26, 2013 10:11 pm
kindly recommend software for the said model application
Postby EViews Glenn » Tue Aug 27, 2013 7:47 am
A Google search of "software for threshold autoregression models " yields as the first two links
http://forums.eviews.com/viewtopic.php?f=4&t=3712
and the following paper
http://ageconsearch.umn.edu/bitstream/3 ... 03za06.pdf
which has links to software.
