Log differenced data and dummy variable regression
KElizabeth925
Hello all-
I am trying to estimate the following ARDL equation: y= a + y(t-i) +o(t-i) +u, where y=quarterly log differenced US GDP and o is quarterly log differenced oil prices (data are all quarterly and lag length=5):
-->I am having an issue with my specification in Eviews for the functional form of "o" : my model is such that oil prices only matter if the log-differenced value is >0. In order to estimate the equation, I have first created a series that is log-differenced oil prices (log_difference_oil). I then created a series for dummy variables, where dummy=1 if log_difference_oil>1.
-->to run the regression accurately, do I specify "log_difference_oil*dummy" as the explanatory variable of oil prices? And then, to account for the lagged data, shall I code it as "log_difference_oil(-1)*dummy(-1)" ..."log_difference_oil(-2)*dummy(-2)?
Is there another way to code the regression such that I do not need to create a new series that reflects the log-differenced oil prices, but rather the code will reflect the fact I want only positive log-differences from the log-oil price series proper?
Just want to make sure that this coding is accurately reflecting what I am trying to accomplish econometrically.
Help very much appreciated--thanks!
Re: Log differenced data and dummy variable regression
It isn't clear what you're trying to do here.
Do you only want to include observations for which log-difference > 0?
Or do you want to estimate different coefficients depending on whether log-difference is > 0 or not?
KElizabeth925
Thanks for your reply. I would like to do both:
Firstly, I would only like to include those observations for which the log-difference is >0.
For example, if in 1953Q:2 the log-difference is 0.14, I would like that observation to be included in the regression.
If, instead, the log-difference is -0.14, I do not want it included in the regression.
After I have that regression sorted, I would then like to estimate a second, "opposite," regression, for which I would only like to include those observations for which the log-difference is negative. At that point I imagine (and hope) the coefficients would be different.
Hope this clarifies...if not please let me know.
Thanks again.
Thanks again.
Specify your equation without dummies. Enter the estimation sample as:
where "o" is the name of your oil price series.
Then do the same thing again, but this time put <0.
@all if dlog(o)>0
KElizabeth925
Brilliant-thanks very much.
I would like to now include three oil price variables: dlog(oil) as it is; dlog(oil) >0; and dlog(oil)<0
Essentially, I am now looking to see the magnitude of each coefficient w/in the same regression.
How best to specify this equations--I assume @all will not work in this case?
Just include those three terms:
Be careful not to put spaces next to the < and >.
From an econometrics point of view, you're probably close to perfect multicolinearity.
dlog(oil) dlog(oil)>0 dlog(oil)<0
KElizabeth925
Right-I'm going to run several variations of this model (next will be to put it into a VAR) but am aware of the possibility of multicolinearity with that particular one-thanks for the heads up though.
Your comments are much simpler to follow and make more sense than trying to create a dummy variable series-thank you!!
KElizabeth925
EViews Gareth:
I ran into an issue using the specification/code that you had posted here, regarding the oil price increases/decreases:
I ran two separate VARs, both with log-differenced GDP and real oil prices as the endogenous variables. In addition, for each regression, I included lagged values if the following exogenous variables:
Regression 1: dlog(oil)>0 (so only positive oil growth counts), and
Regression 2: dlog(oil)<0 (so only negative oil growth counts)
-->I got coefficients of the exact same magnitude, but of opposite sign, for each regression. I know this is not economically feasible, so wondering what could be going on with Eviews...
-->In addition, I ran the exact same code using a different oil price series w/in the VAR framework, and did NOT run into this problem (ie. got different coefficient estimates altogether, different magnitude, different signs, as I'd expect).
Help!
Help!
What you really want to do here is run two separate equations:Hello all-
1. One where the log_difference_oil is always positive
2. One where it's always negative
So you run the exact same regression (equation), but you run it twice, and it's a different sample each time.
The first time, you set the sample as:
@all if log_difference_oil<0Code: Select all
@all if log_differemce_oil>0So yes, this should work. It should also give you the same result as the setup I proposed above.-->to run the regression accurately, do I specify "log_difference_oil*dummy" as the explanatory variable of oil prices? And then, to account for the lagged data, shall I code it as "log_difference_oil(-1)*dummy(-1)" ..."log_difference_oil(-2)*dummy(-2)?
The reason you were getting the same coefficients (but different sign) is because adding a term like
dlog(o)>0-
KElizabeth925
-->Regarding the @all command: I want to run two VARs, where I've got differenced GDP[d(lgdp)] and differenced oil prices[d(loil)] (as they are) as endogenous variables. As additional exogenous variables, I need to include 1) log_difference_oil>0, and then a second VAR where 2)log_difference_oil<0.
-->the @all specification you gave me only allows me to include only positive, or only negative, log differences for oil. How do I code a VAR to allow me to use both d(loil) (including both positive and negative growth) and differenced_oil prices (including only positive growth[and then including only negative growth]) in the same sample?
Thank you!
Thank you!
KElizabeth925
Can someone confirm that this command: dlog(o)>0 is indeed =1 and so a dummy variable for the said specification, rather than a variable which measures the actual positive log-difference effect on GDP? Have gotten conflicting responses. Thanks
Yes, it is a dummy variable.
Type:
in the EViews command window to view it.
Type:
show dlog(o)>0
KElizabeth925
Okay, so in order to account for the magnitude of the effect of positive log-differenced oil on log-differenced GDP, would I then just input:
dlog(o(-1))*dlog(o(-1))>0 dlog(o(-2))*dlog(o(-2))>0
And so on for each lag, into the "exogenous variables" box under the VAR specification tab?
You probably need some parentheses in the expression.
KElizabeth925
Eviews allowed me to run the VAR w/out extra parentheses, though gave results I was not expecting and not sure they are accurate...just checking that my specification mentioned before is correct in measuring the magnitude of positive log-differences.
If so then that's fine
