Dear all,
Using Eviews 8 Jul 26 build, the program is crashing when estimating a .bvar(prior=nw) when the var is subsequently used to 'make model' or forecast (from VARForcast the add-in). Attached is the workfile. The same bug does not occur with the same data for other priors (default settings).
Best wishes!
Charlie
BVAR Normal-Wishart prior Make Model/.forc crash
CharlieEVIEWS
- bvar nw bug report.WF1
- (24.76 KiB) Downloaded 298 times
Re: BVAR Normal-Wishart prior Make Model/.forc crash
Thanks, should be fixed in next patch.
