Dated Data Table Problem
Posted: Wed Jul 03, 2013 9:19 am
by ucfreseachhelp
When I create a Dated Data Table I want to manipulate the Column grouping frequency so that there is only one column. I do so by listing the first column as either "Annual" or "Quarterly" or "Native Frequency" and the second column as "None". However, changing the second column to "None" does not create a permanent change. After applying, okaying, and saving my work the Dated Data Table will not show the second column grouping frequency (the "None" category remains); however, if I quit Eviews (I am using EViews 8) and then reopen the file the second Column grouping frequency reverts to "Native Frequency". Is there any way that I can keep the second column grouping frequency at "None"?
Re: Dated Data Table Problem
Posted: Wed Jul 03, 2013 9:33 am
What's the version and build date of your copy of EViews (both available from the Help->About EViews menu).
Posted: Wed Jul 10, 2013 8:18 am
by ucfreseachhelp
I am using EViews 8 Standard Edition June 19 2013 build.
Posted: Wed Jul 10, 2013 9:54 am
by EViews Jason
Posted: Fri Jul 12, 2013 7:00 am
by ucfreseachhelp
Thank you
