pageunstack
paues
pageunstack
Postby paues » Mon Jun 17, 2013 1:59 am
I just cannot seem to get my head around unstacking data. I have a text file (attached) that I have managed to beat in a alpha series containing the identifiers, which have been transformed into names with the code below. The result is saved in the attached workfile.
'Load text file wfopen "G:\PRO\Map\Arb\Utfall\Ams\Data\Txt\KIS1_201305.TXT" fieldtype=undivided @freq u 'Get date alpha mydate=@mid(series01,1,4)+"M"+@mid(series01,5,2) %mydate=@elem(mydate,"1") delete mydate 'Get id alpha id=@trim(@mid(series01,7,15)) 'Get value series value=@val(@trim(@mid(series01,22))) 'Delete original data delete series01 'Construct valid names alpha name=@makevalidname(id) delete id
My next step would be something involving pageunstack and possibly pagestruct which would result in a dated monthyl workfile (start=2013M05,end=2013M05). I cannot seem to get it to work though. Help would be greatly appreciated.
KIS1_201305.TXT
Original text file
(28.75 KiB) Downloaded 575 times
kis1_201305.wf1
After executed code
(48.62 KiB) Downloaded 422 times
Re: pageunstack
Postby EViews Gareth » Mon Jun 17, 2013 7:59 am
pageunstack namn datum pagestruct @date(datum)
paues
Re: pageunstack
Postby paues » Tue Jun 18, 2013 7:54 am
Worked great. Thanks!
