first zero is missing
tzutzu
Postby tzutzu » Thu Jun 06, 2013 10:40 am
hi guys,
I need your help please. i am trying to import the attached file into a workfile using wfopen command, but instead of having 010, the workfile store as 10.
i am wondering if there is anyway to import the full three digits codes from the file (maybe as a string perhaps)?
Thanks,
code.xls
(48 KiB) Downloaded 606 times
EViews Chris
Re: first zero is missing
Postby EViews Chris » Thu Jun 06, 2013 11:25 am
If you're bringing the file in interactively, just use the combo box on the second page of the import to change the data type of the column from "Number" to "Character".
In a program, you can use a command
wfopen code.xls format=(A)
to do the same thing. (The format option has a list of comma separated column data types where 'A' is alphanumeric, 'F' is (floating point) numeric, and 'D' is date).
Chris
tzutzu
Postby tzutzu » Thu Jun 06, 2013 11:47 am
it works. many thanks Chris
tzutzu
Postby tzutzu » Thu Jun 06, 2013 11:59 am
hi Chris,
i have another question. would it be possible to import the file specify the first column being alphanumeric and the 2nd column being numeric ?
Thank you..
Postby EViews Gareth » Thu Jun 06, 2013 12:56 pm
