Pool object
Pool object
Postby tvonbrasch » Wed Jun 05, 2013 5:39 am
I have a dataset consisting of the variable px?, where ? goes across 260 countries. How do I create a pool object for those 260 countries (i do not want to manually insert the country codes).
One way of doing this is:
pagestack px?
pageunstack(page=pool) var01 id01
but, there must be a better way to do this?
Re: Pool object
Postby EViews Gareth » Wed Jun 05, 2013 7:59 am
Could you post the data?
Re: Pool object
Postby tvonbrasch » Wed Jun 05, 2013 10:12 am
Sure,
If I may ask another question as well. How can I create a pool object that holds only the countries where the variable px has been positive across the sample period (if @min(px?)>1) ?
creating_pool_object_wf.WF1
(306.19 KiB) Downloaded 485 times
Re: Pool object
Postby EViews Gareth » Wed Jun 05, 2013 10:27 am
%ids = @wlookup("px*", "series") %ids = @replace(%ids, "PX", "") pool p {%ids}
To only add some of them, you'd have to loop through, test the minimum, and only add those that passed the test.
Re: Pool object
Postby tvonbrasch » Wed Jun 05, 2013 10:44 am
perfect, thanks
t
