Error: "NA found in matrix in"
Lama
Postby Lama » Thu May 07, 2009 12:00 pm
Dear all,
in my program I get the error ""NA found in matrix in" while trying to execute a for-loop (combined with "if-then-else").
Now I'm stuck: I do not even use a matrix in these operations (just plain series) and I do not understand why NA could be a problem.
I checked, in the series that is tested with an if-then command there are some NA but there are "valid" values, too.
I'd be very grateful if somebody could help me
Yours,
Lama
Re: Error: "NA found in matrix in"
Postby EViews Gareth » Thu May 07, 2009 12:10 pm
We'll need more information.
The ideal situation would be for you to post the workfile and the program...
Lama
Postby Lama » Thu May 07, 2009 11:29 pm
Hi Gareth,
of course you're right.
(The program should result in a season's overall score.)
eviews1.prg
(769 Bytes) Downloaded 738 times
Eviewswkfile1.WF1
(28.95 KiB) Downloaded 588 times
Thanx a lot!
Lama
trubador
Did you use forum search?
Postby trubador » Fri May 08, 2009 4:50 am
It seems, as a first impression, your specification of IF statement is incorrect. You should check the following link for an example similar to your case: http://forums.eviews.com/viewtopic.php?f=5&t=799#p2679 Other than that, what you are trying to achieve is still somewhat ambiguous. If possible, please give some more information on the variables and definiton of your problem...
Lama
Postby Lama » Sat May 09, 2009 5:26 am
Hi Trubador,
thanks a lot for your hint.
The problem now is fixed: I just forgot to tell EVIEWS which particular element in the series had to be increased. Now the error does not occur anymore.
Sorry for bothering you & thanks again
Lama
