problem freezing graphs with transformations
ghammond_eller
Postby ghammond_eller » Fri May 10, 2013 9:49 am
Hi, I'm using Eviews 7.2 Enterprise
I'm encountering a problem freezing a graph with transformed data (ie displaying data at annual percent changes or year-over-year percent changes).
Basically, I do the following:
1)create group with 2 or more series
2)View as line graph
3)Pull down transform menu and choose Year % Chg, for instance
4)Click Freeze Button
5)Click Automatic - Update button
6)Click Update when data or the workfile sample changes
7)click OK
The resulting graph object then displays the data using the simple period to period percent change (% Change)
Can you tell me what's going on?
I've attached the workfile.
eviews_problem.wf1
(19.38 KiB) Downloaded 196 times
Re: problem freezing graphs with transformations
Postby EViews Gareth » Fri May 10, 2013 10:00 am
Looks like a bug, we'll investigate.
