help for unit root test
tanghanpost
Postby tanghanpost » Tue May 05, 2009 6:05 am
hi,
i am now confused with the unit root test. i read from some textbook that i can use the eviews's unit root test ouput critical value for adjudgement on unit root. but my teacher tell me it is wrong when i use the critical value for a unit root test on a residual from a equation, for AEG test has differnt critical value, but then how can i carry out a unit root test for the equation residual series?
thanks a lot!
Re: help for unit root test
Postby EViews Glenn » Tue May 05, 2009 6:38 am
Your instructor is correct. You could run the test on the residuals and then look up the critical values in the Engle-Granger paper or in one of the other sources for simulated values.
There was a recent set of threads on this issue.
http://forums.eviews.com/viewtopic.php? ... nger#p2364
http://forums.eviews.com/viewtopic.php? ... lues#p1647
