I would appreciate any help regarding my panel data.
I followed the instructions under the eviews guide, but I cannot solve my issue.
I need to to make a panel analysis and generate a fixed effect output for each country. However,
I get my fixed effect ones, just for the whole file. Please have look on my excel file and suggest me how should I structure my data properly to
get the fixed effect for each country?
Panel data analysis
filip.tomic1
Panel data analysis
- Panel.data.fff.xlsx
- (14.35 KiB) Downloaded 415 times
Re: Panel data analysis
You're probably better off supplying your workfile rather than the Excel file.
filip.tomic1
Here is the workfile.
- panel.data.analysis1.WF1
- (15.47 KiB) Downloaded 329 times
And what is the equation you are trying to estimate?
filip.tomic1
regression model : y=ß0+ß1x1+ß2x2+ß3x3
eviews equation: "name of the dependent variable" c "independent variable1" independent variable2 "independent variable3"
However, I would like to have receive the fixed effect for each country, maybe my equation is wrong?
When you estimate an equation there is a panel options tab. You can choose fixed effects there.
