Dynamically get F stats for hettest on each regression
benlambert18785
Postby benlambert18785 » Tue Apr 09, 2013 6:16 am
I am currently creating equations dynamically within a program, and then storing the results of this to a table. I am fine to collect the t stats etc. by using the relevant commands on the equation object which I have created.
However, I am having some issues with trying to collect (in my table) the results of hettest on each of those objects.
I would like to capture the F stat along with the F stat's associated p value in my table.
I can use the following code to do a Breusch-Pagan test on an equation object (with the auxillary regression having three independent variables c ds_eon and d_eon):
z_aus_eon.hettest(type=BPG) c ds_eon d_eon
However, I really don't have a clue as to how to record the F stat (and it's associated p value) as one of the values in my table.
I have tried @f, but this brings up the F stat for the actual regression rather than the auxillary one used to test for heteroscedasticity.
Any help as to how I can do this would be most appreciated!
Many thanks,
Ben
Re: Dynamically get F stats for hettest on each regression
Postby EViews Gareth » Tue Apr 09, 2013 7:51 am
benlambert18785
Postby benlambert18785 » Tue Apr 09, 2013 9:04 am
Hi Gareth,
That's great - many thanks. Just for anyone else who runs into this issue I thought I would post my code. This pulls the F statistic for a hettest together with its associated p value.
table(770,2) ztab freeze(tab1) zzz_{%i}.hettest(type=BGP) c ds_eon d_eon ztab(!j+1,1) = @val(tab1(3,2)) ztab(!j+1,2) = @val(tab1(3,5))
Thanks,
Ben
