R1C1 reference format when exporting to xlsx?
paues
Postby paues » Sat Apr 06, 2013 5:08 am
Would it be possible to add support for the R1C1 cell reference format when exporting to Excel files (.xls, .xlsx and .xlsm)? If this feature was available these two lines would give the same result.
pagesave(t=excelxml) "k:\stab\test.xlsx" range="Sheet1!A1" pagesave(t=excelxml) "k:\stab\test.xlsx" range="Sheet1!R1C1"
It would save users the hassle of having to create things such as the subroutine below in case they need to loop exports.
subroutine GetExcelColumnName(scalar !v, string %name) if @floor(!v)<>!v then @uiprompt("The parameter !v ("+@str(!v)+") must be an integer.") stop endif if !v<1 or !v>16384 then @uiprompt("The parameter !v ("+@str(!v)+") cannot be outside the range 1-16384.") stop endif %alphabet="A B C D E F G H I J K L M N O P Q R S T U V W X Y Z" !dividend=!v %columnName="" while !dividend>0 !modulo=@mod((!dividend-1),@wcount(%alphabet)) %columnName=@word(%alphabet,!modulo+1)+%columnName !dividend=@floor((!dividend-!modulo)/@wcount(%alphabet)) wend string {%name}=%columnName endsub
P.S. The method in the subroutine comes from this Stack Overflow post.
Re: R1C1 reference format when exporting to xlsx?
Postby EViews Jason » Tue Apr 09, 2013 4:45 pm
It will be available in the next patch
paues
Postby paues » Tue Apr 09, 2013 9:55 pm
Great! Thanks :-)
