BVAR SEs not computed
batotai
Postby batotai » Wed Feb 20, 2013 3:36 am
My code is bugging with certain parameters settings but I fail to see the reason ? The error message is "Note that some SEs have not been computed", which I don't get as the estimation is going all right at t-1 but not at t ? See below...
Thanks for your advices !
[img]
[/img]
Re: BVAR SEs not computed
Postby EViews Gareth » Wed Feb 20, 2013 8:53 am
You're probably better off using the EViews 8 beta and the build-in BVAR options.
batotai
Postby batotai » Fri Feb 22, 2013 5:38 am
Ahah yes I suppose but as for now my organisation doesn't have it available, and as it seems the estimation is done properly (forecasts get computed even with those missing SEs), I wonder if there's not a way to skip the "Note" message that stops the program ? It doesn't work with the error number setting, as it's not considered as an error by Eviews apparently...
Postby EViews Gareth » Fri Feb 22, 2013 8:37 am
You'll have to look at the BVAR source code and simply remove the line that puts up that message.
Return to “Add-in Support”
