Can eviews do backcast in ARIMA models?
masxupeng
Postby masxupeng » Wed Jan 16, 2013 8:05 am
we know that eviews can do forecast. Can eviews do backcast in ARIMA models? If yes, how can eviews do it? thanks!
Re: Can eviews do backcast?
Postby EViews Gareth » Wed Jan 16, 2013 8:21 am
Depends on what you mean by backcast. But in general, you can set the forecast sample to be anything, including periods pre-estimation sample.
trubador
Did you use forum search?
Postby trubador » Wed Jan 16, 2013 8:25 am
If you are referring to dynamic models (e.g. ARIMA), then you'll need a little trick. Since backcasting is essentially a forecasting backwards from the initial point, you can reverse the order of data:
series rev = @trend sort(d) rev
masxupeng
Postby masxupeng » Wed Jan 16, 2013 8:48 am
i set it. but i could not get backcast outcome with your method of setting the forecast sample to be anything.
Postby EViews Gareth » Wed Jan 16, 2013 8:50 am
Perhaps you should explain in more detail what you're trying to do.
masxupeng
Postby masxupeng » Wed Jan 16, 2013 8:51 am
thanks a lot! can you recommand some papers for me?
masxupeng
Re: Can eviews do backcast in ARIMA models?
Postby masxupeng » Wed Jan 16, 2013 8:53 am
we know that eviews can do forecast . Can eviews do backcast in ARIMA models?? If yes, how can eviews do it? thanks!
masxupeng
Postby masxupeng » Wed Jan 16, 2013 8:57 am
backcast in ARIMA models! thanks for your suggestion
