rolling window help
g_anluca
rolling window help
Postby g_anluca » Tue Apr 21, 2009 12:41 pm
greetings everyone!
i am trying to do a rolling window static forecast out of a simple ECM model but i cannot manage to obtain the complete forecast: that is when i look in the forecast output (wtifore) i only get the results for the last iteration of the loop. here's the code
scalar obs=5490
scalar window= 500
for !i = window to obs-window
smpl !i-window+1 !i
equation prova_ecm
prova_ecm.ls d(wti) c d(wti_f3) u(-1)
smpl !i+1 !i+window
prova_ecm.fit wtifore
smpl @all
i know i should create something to contain the forecasted values after each iteration to avoid overwriting them, but i just can't figure out how. can anyone help me?
tx in advance [edit: i'll attach also the wf]
ecm.WF1
(186.07 KiB) Downloaded 472 times
trubador
Did you use forum search?
Re: rolling window help
Postby trubador » Fri May 01, 2009 3:10 am
Try this way:
scalar obs=5490 scalar window= 500 matrix(window,obs-2*window+1) results for !i = window to obs-window smpl !i-window+1 !i equation prova_ecm prova_ecm.ls d(wti) c d(wti_f3) u(-1) sample s !i+1 !i+window prova_ecm.fit wtifore stom(wtifore,rvector,s) colplace(results,rvector,!i-window+1) delete s rvector next smpl @all
