"No valid observations" problem in SUR estimation
andrew
Postby andrew » Mon Jan 07, 2013 6:31 pm
I tried to estimate a three-equation system using SUR, but an error message box pops out saying "no valid observations" in the last equation. I don't know what this is all about or how to do with it. I uploaded the workfile in the attachment. Can anybody take a look and help me? Thanks in advance!
sur.wf1
(12.94 KiB) Downloaded 318 times
Re: "No valid observations" problem in SUR estimation
Postby EViews Gareth » Mon Jan 07, 2013 7:15 pm
At your current starting values (0 for all coefficients), the third expression in your system evaluates to all NAs, which gives no valid observations. Use different starting values (I set C equal to 1, and it seemed to work).
andrew
Postby andrew » Tue Jan 08, 2013 11:49 am
Problem solved. Thanks so much!
Bulldozer
Postby Bulldozer » Mon Jan 28, 2013 7:21 pm
I get the same error message, but when estimating the system for VECM. I have four series, I have run the JJ cointegration and found there are more than one cointegration vectors, I then run VECM, made the system (Proc>>Make System), then I tried to get the significance values through system estimation (Estimate), but the Error Message came up (No valid observation in equation....). Any suggestions?
massoud982000
Postby massoud982000 » Thu Mar 21, 2013 11:27 pm
Dear friends,
I faced the same problem as Andrew in Eviews, I would kindly request you to help me
((I tried to estimate a three-equation system using SUR, but an error message box pops out saying "no valid observations" in the last equation. I don't know what this is all about or how to do with it. I uploaded the workfile in the attachment. Can anybody take a look and help me?))
Please find the file I have attached ( I run VECM with 2 endogenous variables )
I am so thankful of your favor in advance.
Massoud
My Email: massoud982000@yahoo.com
acc vecm.wf1
Thanks in advance
(23.32 KiB) Downloaded 276 times
Postby EViews Gareth » Fri Mar 22, 2013 7:48 am
Hard to help without knowing exactly what you're doing.
