Hope this isn't too basic... but I couldn't find a solution on my own or on the forum.
I'm passing a group of exo series and a dependent series to R and retrieving a coefficient array (n rows x 1 col) from the NNLS package from R.
I'd like to create a new equation using the new coefficient array and the group of exo series.
The issue is that this is in a loop so the size of the group (and series therein) and length of the coeff array will constantly be changing. I think it's the equivalent of vector multiplication between the coef array and the series within the group, but I'm not sure how to do this.
Any suggestions? Thanks.
Creating an equation from a coefficient vector and a group
Re: Creating an equation from a coefficient vector and a gro
I'm not quite sure what you're trying to do. Estimate an equation with fixed coefficients?
Well, I don't know if its estimate per se, but yes, create a number of equations based on a varying coefs vector and different groups of variables. The equations will then be used for forecasting and to feed other estimation methods. In concept it's reducing a large number of Econometric variables through NNLS (almost like stepwise LS) and then continuing the analysis back in eviews. Thanks for any help.
Unfortunately you cannot create an equation with fixed coefficients for use in forecasting.
However, you can use a model object (indeed, that's what a model object is for).
You'll still have to write a loop to add them all though. You'll have to loop through the members of the group using group.@seriesname, and loop through the elements of the coefficient vector.
So I'm sure there is a more elegant way to do this, both statistically and programmatically, but...
The approach is to (1) bring the fitted values back from the NNLS function in R (2) fit an EViews LS equation with the full group of independent variables (fortunately EViews always seems to come up with the exact same coefficients) and (3) clean-up the "near 0" coefficients in the new LS equation, by adding any variables with coefficients greater than a particular value.
smpl 2002m01 2012m11 'set sample period for NNLS
xopen(type=r, case=upper) 'open a connection to R with upper-case default output names
xput(rtype=data.frame,name=m1) econs 'put regressors and dependent variable into R
xput(rtype=data.frame, name=m2) depen
xrun "library (nnls)" 'load NNLS package in R
xrun "rm1 <- as.matrix(m1)" 'NNLS needs data in matrix form
xrun "rm2 <- as.matrix(m2)"
xrun "nnlsout <- nnls (rm1,rm2)" 'run NNLS
xrun "nncoef <-coef(nnlsout)" 'get NNLS coefficients
xrun "nnfit <- fitted(nnlsout)" 'get NNLS fitted data
xget(name=nncoef, type=vector) nncoef 'retrieve coefs into EViews
xget(name=nnfit, type=series) nnfit 'retrieve NNLS fitted data into EViews
equation e1.ls nnfit econs 'create first EViews equation with regressors
%nnvarslist = e1.@varlist 'get list of E1 variables
%nnvarslist2 = @replace(%nnvarslist,"NNFIT","") 'remove fitted series from list
group econs2 'create new group
econs2.drop *
!i=1
for %e2 {%nnvarslist2} 'put NNLS variables into a reduced group of regressor
%nnvar = @wlookup(%e2)
if e1.@coef(!i) > .00001 then
econs2.add {%nnvar} 'add only variables with significant coefficients
endif
!i = !i +1
equation eq2.ls nnfit econs3 'fit the reduced variable group to the NNLS output
xclose 'close R connection
