Different estimates based only on the order of the instrumen
EconGrp
Postby EconGrp » Mon Dec 10, 2012 10:08 am
Hi.
I have this weird problem:
I am estimating a panel tsls.
The estimation of the model is done encountering no errors or anything of the sort. But when I try to place the instruments in a different order, something really weird happens: my estimates change!
That is,
the case where the instruments are placed in this order
Instr(1) Instr(2) Instr(3)
and the case where they are placed like this (for example)
Instr(1) Instr(3) Instr(2)
, differ in terms of the estimates.
Does anyone have a clue about what is going on?
Re: Different estimates based only on the order of the instr
Postby EViews Gareth » Mon Dec 10, 2012 10:16 am
Could you let us know your EViews version number, your build date (available from Help->About EViews), and, if possible, post your workfile.
EconGrp
Postby EconGrp » Mon Dec 10, 2012 10:25 am
Eviews 7.1
Sep 10 2010 build
Can't post the workfile atm... but there is some missing data for some of the cross sections, for some of the periods - could that be the problem?
Postby EViews Gareth » Mon Dec 10, 2012 10:27 am
Please update to the latest version of EViews 7. You can download the latest update patch from the help menu, or from here:
http://www.eviews.com/downloads/
EconGrp
Postby EconGrp » Mon Dec 10, 2012 10:30 am
Ok, thanks - I'll do that.
But do you think that will solve the problem?
Postby EViews Gareth » Mon Dec 10, 2012 10:32 am
Hopefully.
EconGrp
Postby EconGrp » Mon Dec 10, 2012 12:12 pm
Doesn't work :/
Postby EViews Gareth » Mon Dec 10, 2012 12:16 pm
How many instruments did you add, and what is the reported instrument rank?
EconGrp
Postby EconGrp » Mon Dec 10, 2012 12:50 pm
I have 7 explanatory variables and a constant. Only one of the explanatory variables is endogenous, and I only got 1 instrument for this. The remaining exogenous explanatory variables I use as instruments for themselves.
I have an instrument rank on 209.
I have 217 individuals in the cross section.
Postby EViews Gareth » Mon Dec 10, 2012 12:57 pm
When you get the different results, do you have the same number of observations reported?
EconGrp
Postby EconGrp » Mon Dec 10, 2012 1:14 pm
Yes - I do.
Postby startz » Mon Dec 10, 2012 1:48 pm
I'm not sure I'm reading this right, but do you have 209 instruments with 217 observations???? Otherwise something is very screwy, because the instrument rank can't be higher than the number of instruments.
Even if you can't post your workfile, you might want to post your output.
Postby EViews Glenn » Mon Dec 10, 2012 2:38 pm
It's a panel. I assume he's doing fixed effects and we're counting the implicit dummy variables as instruments.Though it sounds as though he has fewer than 217 in his final estimation sample.
EconGrp
Postby EconGrp » Tue Dec 11, 2012 9:12 am
I have tested the problem using different data - and even though the difference in estimates isn't big, the problem seems to endure over different workfiles.
So I ignore it for now.
I'm now facing a different problem: How do Eviews manage unbalanced panels? Does the program automatically change the estimators, so they'll fit the partly missing data? And is there an easy way to exclude cross sections with missing data, so I only use the balanced panel?
Thanks in advance
Postby EViews Gareth » Tue Dec 11, 2012 9:18 am
I cannot replicate what you're seeing at all. The following program creates random data on an unbalanced panel, and always gets identical results for the three equations (even though the order of instruments is different):
create a 1990 2020 20 series y=nrnd series x1=nrnd series x2=nrnd series z1=nrnd series z2=nrnd series z3=nrnd series z4=nrnd 'make unbalanced smpl if nrnd>1.1 y = na pagecontract if y<>na smpl @all equation eq1.tsls(cx=f) y c x1 x2 @ c z1 z2 z3 z4 equation eq2.tsls(cx=f) y c x1 x2 @ c z2 z4 z1 z3 equation eq3.tsls(cx=f) y c x1 x2 @ c z3 z1 z4 z2
