Different lag lengths in a VAR model
Marqito
Postby Marqito » Fri Dec 07, 2012 12:40 pm
Hi!
Im doing a VAR(9) model and I was wondering if it is possible to have different lag length on each variable. And if so, how do I create my VAR-model with different lag.
Example: I have x1, x2, x3, x4, x5, x6, x7, x8, x9.
And I want a VAR model with:
x1=x1t-1+ x2t-1+ x3t-1+ x4t-1+ x5t-1+ x6t-1+ x7t-1+ x8t-1+ x9t-1+ x1t-2+ x2t-2+ x3t-2+ x4t-2 + x1t-3+ x2t-3+ x3t-3+ x4t-3+ x5t-3+ x6t-3+ x1t-4+ x2t-4+ x3t-4+ x4t-4+ x5t-4+ x6t-4+c
x2= x1=x1t-1+ x2t-1+ x3t-1+ x4t-1+ x5t-1+ x6t-1+ x7t-1+ x8t-1+ x9t-1+ x1t-2+ x2t-2+ x3t-2+ x4t-2 + x1t-3+ x2t-3+ x3t-3+ x4t-3+ x5t-3+ x6t-3+ x1t-4+ x2t-4+ x3t-4+ x4t-4+ x5t-4+ x6t-4+c
x3= x1=x1t-1+ x2t-1+ x3t-1+ x4t-1+ x5t-1+ x6t-1+ x7t-1+ x8t-1+ x9t-1+ x1t-2+ x2t-2+ x3t-2+ x4t-2 + x1t-3+ x2t-3+ x3t-3+ x4t-3+ x5t-3+ x6t-3+ x1t-4+ x2t-4+ x3t-4+ x4t-4+ x5t-4+ x6t-4+c
x4= x1=x1t-1+ x2t-1+ x3t-1+ x4t-1+ x5t-1+ x6t-1+ x7t-1+ x8t-1+ x9t-1+ x1t-2+ x2t-2+ x3t-2+ x4t-2 + x1t-3+ x2t-3+ x3t-3+ x4t-3+ x5t-3+ x6t-3+ x1t-4+ x2t-4+ x3t-4+ x4t-4+ x5t-4+ x6t-4+c
and so on.
In practice this is not impossible to do, but I don’t understand how I can do it in eviews.
Thanks for the help!
Re: Different lag lengths in a VAR model
Postby EViews Gareth » Fri Dec 07, 2012 2:02 pm
It is not possible using the built in VAR object. You can, however, use a System object to do it. I would start off by building the VAR (with same lag lengths), then use the Proc->Make System option to build a system object, then manually edit the system to knock off the unwanted lag parts.
The downside is that you won't get to be able to use the built in VAR features (notably impulse responses).
Marqito
Postby Marqito » Mon Dec 10, 2012 1:37 am
I build the VAR with lagg 4, then i go to Proc-> make System option, but then i get order by variable, order by lag... what shall i do then? how do i manually edit the system to know of the unwanted lag parts?
Postby EViews Gareth » Mon Dec 10, 2012 5:20 am
Choose either.
