System GMM
margerita
System GMM
Postby margerita » Thu Apr 16, 2009 5:08 am
Does Eviews include sys-GMM?
Thanks.
Re: System GMM
Postby startz » Thu Apr 16, 2009 7:04 am
yes
margerita
Re: System GMM
Postby margerita » Thu Apr 16, 2009 8:47 am
Thanks, startz.
and how do you apply it?
Re: System GMM
Postby startz » Thu Apr 16, 2009 8:59 am
Thanks, startz.
That depends on whether you're using the command line or working interactively. If you told us what you've tried, we might be able to give you a more focused answer.
margerita
Re: System GMM
Postby margerita » Thu Apr 16, 2009 2:35 pm
So far I've been using only dynamic panel wizard...
Re: System GMM
Postby EViews Gareth » Thu Apr 16, 2009 2:36 pm
Just to be clear, are you talking about applying GMM to a system of equations, or are you talking about the Dynamic Panel Data System estimator of Blundell-Bond (if memory serves me correctly).
If it is the latter, then no EViews does not do it.
Edit: just saw your above post, which means, I guess, that you are talking about the Dynamic Panel Data method. Which means you're out of luck, I'm afraid.
margerita
Re: System GMM
Postby margerita » Mon Apr 20, 2009 8:34 am
yes, I meant Blundell&Bond estimator. Thank you.
I guess the Arellano&Bond and Arellano&Bover will have to do the job :)
kelaynak
Re: System GMM
Postby kelaynak » Thu Jan 14, 2010 3:54 pm
In eviews 7, Is there a support for dynamic panel system estimator (Arellano&Bond and Arellano&Bover )for a system equations?
If no,
-will it be included in future updates of eviews 7 ?
-or it is no because, it is not possible to to use dynamic system estimators for a system equations theoretically? and it is not included in other econometrical packages?
Thank you for your help
