Residual check
jlbrillet
Residual check
Postby jlbrillet » Tue Apr 14, 2009 6:35 am
Sometimes the "d=f" option in the SOLVE statement does not work. It seems to use data from the previous period uinstead of the present one.
This is true even for simple equations (and easy to control manually) such as : x = y + z.
Jean Louis Brillet.
Re: Residual check
Postby EViews Gareth » Tue Apr 14, 2009 8:08 am
Could you give us a more concrete example?
jlbrillet
Re: Residual check
Postby jlbrillet » Wed Apr 15, 2009 5:33 am
Sorry, this bug seems to have disappeared with EViews 6.
I just ran the very same program on the very same files with the two versions. 6 works, not 5.
In an equation for labour productivity :
PL = Q / LF
Version 5 actually computed :
PL = Q(-1)/LF
Both Q and LF appear as lagged in other parts of the program, Q with lag 2.
Jean Louis B.
Re: Residual check
Postby EViews Gareth » Wed Apr 15, 2009 8:10 am
ok.
Obviously we're no longer fixing bugs in EViews 5, so we probably fixed it at some point in 6.
Re: Residual check
Postby EViews Glenn » Wed Apr 15, 2009 11:59 am
You should check your copy of EViews 5 against the final version posted in the downloads area.
