I estimated my model with Maximum Likelihood assuming a student t distribution. Now I would like to test if my errors are indeed t distributed. How can I test this in Eviews?
Steven
Testing if my errors are student t distributed
Re: Testing if my errors are student t distributed
Open up the residual series, click on View->Descriptive Statistics->Empirical distribution tests.
Thanks for your reply.. However, the reason for my question is that the student t distribution is not in that list...
Ah, yes. That's what I get for answering before breakfast. You can do a Quantile-Quantile plot against the t-distribution to get an eyeball of how close the distribution is.
Thanks!
I managed to do it manually. However, if I want to include it in a program, then my command always plots the data against the normal distribution instead of the t distribution... This is my code:
growth.qqplot theory(dist=tdist)
where growth is the series with the data.
What am I doing wrong here?
Looks like a bug. Let me check into it.
[edit: I've put a fix into the main code base. It should show up in the next update.]
