Bv_Egarch code conversion.
bilal
Postby bilal » Wed Sep 05, 2012 2:34 pm
Hello.
i was searching for the Bivarite Egarch codes for simple time Series Data with 2 variables in this forum but i found the code OF "EGARCH OF Panel DATA" its brilliant work done . i tried my level best to understand it fully and reduce it to the Bi-variate Egarch Version but every time i got new error. can any one please Edit it so that i can estimate volatility spillover b/w Stock and foreign Exchange.
my variables are 1Stock indices 2Exchange Rate
THE AUTHOR used 17 countries in the panel and i guess two Variables
The code is given below
{%X} is used for different countries
i will be obliged for this help
'change path to program path %path=@runpath cd %path 'load workfile containing the return series load unstacked.wf1 smpl @all %x ="us" !p = 4 !q = 2 'Estimate the conditional mean using VAR var {%x}_var.ls 1 !p e_{%x} s_{%x} @ show {%x}_var.output 'Generate residual series form var {%x}_var.makeresids() {%x}_e {%x}_s ' set sample ' first observation of s1 need to be one or two periods after the first observation of s0 sample s0 2/5/1999 8/26/2011 sample s1 2/19/1999 8/26/2011 ' initialization of parameters and starting values smpl s0 'get starting values from univariate GARCH equation {%x}_egarch1.ARCH(1,!q,EGARCH,H,BACKCAST=0.7,DERIV=AA) {%x}_e equation {%x}_egarch2.ARCH(1,!q,EGARCH,H,BACKCAST=0.7,DERIV=AA) {%x}_s ' declare coef vectors to use in bi-variate Panel EGARCH model coef(2) {%x}_alpha0 {%x}_alpha0(1)= {%x}_var.c(1,1+2*!p) {%x}_alpha0(2)= {%x}_var.c(2,1+2*!p) for !n=1 to !p coef(4) {%x}_alpha!n {%x}_alpha!n(1)= {%x}_var.c(1,!n) {%x}_alpha!n(2)= {%x}_var.c(1,!n+!p) {%x}_alpha!n(3)= {%x}_var.c(2,!n) {%x}_alpha!n(4)= {%x}_var.c(2,!n+!p) next coef(2) {%x}_beta0 {%x}_beta0(1)= {%x}_egarch1.c(1) {%x}_beta0(2)= {%x}_egarch2.c(1) coef(4) {%x}_beta1 {%x}_beta1(1)={%x}_egarch1.c(2) {%x}_beta1(2)=0 {%x}_beta1(3)=0 {%x}_beta1(4)={%x}_egarch2.c(2) coef(2) {%x}_delta {%x}_delta(1) = {%x}_egarch1.c(3)/{%x}_egarch1.c(2) {%x}_delta(2) = {%x}_egarch2.c(3)/{%x}_egarch2.c(2) for !m=1 to !q coef(2) {%x}_gamma!m {%x}_gamma!m(1)= {%x}_egarch1.c(!m+3) {%x}_gamma!m(2)= {%x}_egarch2.c(!m+3) next coef(3) {%x}_eta {%x}_eta(1) = 0.5 {%x}_eta(2) = 0.05 {%x}_eta(3) = 0.9 ' use var-cov of sample in "s0" as starting value of variance-covariance matrix series {%x}_var_e = @var({%x}_e) series {%x}_var_s = @var({%x}_s) series {%x}_z_e = {%x}_e/@sqrt(@var({%x}_e)) series {%x}_z_s = {%x}_s/@sqrt(@var({%x}_s)) series {%x}_xi = -log((1-@cor({%x}_e,{%x}_s))/(1+@cor({%x}_e,{%x}_s))) series {%x}_cor=2/(1+@exp(-{%x}_xi))-1 series {%x}_cov={%x}_cor*@sqrt(@var({%x}_e)*@var({%x}_s)) scalar E_z=@sqrt(2/@acos(-1)) ' ........................................................... ' LOG LIKELIHOOD ' set up the likelihood ' 1) open a new blank likelihood object (L.O.) name bvegarch ' 2) specify the log likelihood model by append ' ........................................................... logl {%x}_bvegarch {%x}_bvegarch.append @logl logl {%x}_bvegarch.append {%x}_e = E_{%x} - ({%x}_alpha0(1) + {%x}_alpha1(1)*E_{%x}(-1) + {%x}_alpha2(1)*E_{%x}(-2) + {%x}_alpha3(1)*E_{%x}(-3) + {%x}_alpha4(1)*E_{%x}(-4) + {%x}_alpha1(2)*S_{%x}(-1) + {%x}_alpha2(2)*S_{%x}(-2) + {%x}_alpha3(2)*S_{%x}(-3) + {%x}_alpha4(2)*S_{%x}(-4)) {%x}_bvegarch.append {%x}_s = S_{%x} - ({%x}_alpha0(2) + {%x}_alpha1(3)*E_{%x}(-1) + {%x}_alpha2(3)*E_{%x}(-2) + {%x}_alpha3(3)*E_{%x}(-3) + {%x}_alpha4(3)*E_{%x}(-4) + {%x}_alpha1(4)*S_{%x}(-1) + {%x}_alpha2(4)*S_{%x}(-2) + {%x}_alpha3(4)*S_{%x}(-3) + {%x}_alpha4(4)*S_{%x}(-4)) {%x}_bvegarch.append {%x}_z_e = {%x}_e/@sqrt(@var({%x}_e)) {%x}_bvegarch.append {%x}_z_s = {%x}_s/@sqrt(@var({%x}_s)) ' calculate the variance and covariance series {%x}_bvegarch.append log({%x}_var_e) = {%x}_beta0(1) + {%x}_beta1(1)*(abs({%x}_z_e(-1))-E_z+{%x}_delta(1)*{%x}_z_e(-1)) + {%x}_beta1(2)*(abs({%x}_z_s(-1))-E_z+{%x}_delta(2)*{%x}_z_s(-1)) + {%x}_gamma1(1)*log({%x}_var_e(-1)) + {%x}_gamma2(1)*log({%x}_var_e(-2)) {%x}_bvegarch.append log({%x}_var_s) = {%x}_beta0(2) + {%x}_beta1(3)*(abs({%x}_z_e(-1))-E_z+{%x}_delta(1)*{%x}_z_e(-1)) + {%x}_beta1(4)*(abs({%x}_z_s(-1))-E_z+{%x}_delta(2)*{%x}_z_s(-1)) + {%x}_gamma1(2)*log({%x}_var_s(-1)) + {%x}_gamma2(2)*log({%x}_var_s(-2)) {%x}_bvegarch.append {%x}_z_e = {%x}_e/@sqrt({%x}_var_e) {%x}_bvegarch.append {%x}_z_s = {%x}_s/@sqrt({%x}_var_s) {%x}_bvegarch.append {%x}_xi = {%x}_eta(1) + {%x}_eta(2)*{%x}_z_e(-1)*{%x}_z_s(-1) + {%x}_eta(3)*{%x}_xi(-1) {%x}_bvegarch.append {%x}_cor=2/(1+@exp(-{%x}_xi))-1 {%x}_bvegarch.append {%x}_cov={%x}_cor*@sqrt({%x}_var_e*{%x}_var_s) ' determinant of the variance-covariance matrix {%x}_bvegarch.append {%x}_deth = {%x}_var_e*{%x}_var_s - {%x}_cov^2 ' log-likelihood series {%x}_bvegarch.append logl =-0.5*(2*1*(660-!p)*log(2*@acos(-1)) + log({%x}_deth) + ({%x}_e^2*{%x}_var_s + {%x}_s^2*{%x}_var_e - 2*{%x}_cov*{%x}_e*{%x}_s)/{%x}_deth) ' estimate the model smpl s1 {%x}_bvegarch.ml(showopts, m=500, c=1e-6) ' change below to display different output show {%x}_bvegarch.output graph {%x}_vare.line {%x}_var_e graph {%x}_vars.line {%x}_var_s graph {%x}_coves.line {%x}_cov graph {%x}_cores.line {%x}_cor show {%x}_vare show {%x}_vars show {%x}_coves show {%x}_cores
unstacked.wf1
work file for the given Code
(286.9 KiB) Downloaded 299 times
bilal
Re: Bv_Egarch code conversion.
Postby bilal » Mon Sep 10, 2012 3:48 pm
Isn't this possible for the helping moderators? from the very first day i didn't get any kind of help form this forum. its very disappointing
Postby startz » Mon Sep 10, 2012 4:30 pm
You want someone to program for you and you're disappointed when no one will do your work for you?
bilal
Postby bilal » Tue Sep 11, 2012 9:37 am
it looks as if you didn't read above!....
no one is needed to program .... it is done by someone already .... the only thing needed was truncation only :wink:
