insufficient number of observations eviews
Scalper
Postby Scalper » Sat Aug 11, 2012 8:31 am
Dear all,
When i am testing the cointegration test or even estimating the VEC model the eviews shows up with "insufficient number of observations" and i dont know why.
If you could help me , i would appreciate that kindness
Scalper
alemanha svar 2.wf1
(24.32 KiB) Downloaded 869 times
Re: insufficient number of observations eviews
Postby EViews Gareth » Mon Aug 13, 2012 2:04 pm
You haven't provided any information on exactly what you're trying to do, so it is hard to give information on why it isn't working.
However, if I were to hazard a guess, I would say that the most likely cause of that error message is that you do not have enough observations in your workfile to perform the VEC estimation you wish to perform.
Eviewsbeginner
Postby Eviewsbeginner » Tue Oct 23, 2012 11:40 am
Dear Sir,
I got the same problem. I am trying to run the below equation.
Log(export) = c + log(gdpA) + log(gdpB) + log(popA) + log(popB) + log(dist) + tariff
The data are balanced panel data of 14x744 = 10,416 observation.
The equation can be estimated successfully, if I run the following equation.
However, if I add one more variable (or more), i.e.:
It could not be estimated at all. The program indicates that "insufficient number of observations" all the times.
What is wrong with my estimation? Please help me to sort it out. Thank you very much.
Postby EViews Gareth » Tue Oct 23, 2012 12:37 pm
Most likely cause is that the variables you are adding do not have enough observations.
yong yee
Postby yong yee » Tue Apr 02, 2013 2:41 am
Hi. My regression model is:
ln FDI = c + log (gdp) + log (nominal exchange rate) + log (open)
When I try to get estimate equation by using OLS, the pop-out window showed me that error message: insufficient number of observations.
Anyone can help? Thanks.
fdi.wf1
(11.02 KiB) Downloaded 769 times
Postby startz » Tue Apr 02, 2013 6:49 am
Take a look at the data series you are using in the regression.
