Help Needed to Get Program to Run Existing Workfile Data
Posted: Thu Aug 09, 2012 8:24 am
by bjonyou
Hello All,
This is probably a very basic question but I am new to EViews and have no coding experience. I have been running regression and have all my dependent and independent variables set up in a workfile. However, I just created and tried to run a program to alleviate the repetition but I'm getting an error message that states:
Workfile_Data is not defined in "DO_Workfile_Data.WF1d Q 1930 2014".
I have no clue what this means an what I'm doing wrong. Can anyone help me?
Re: Help Needed to Get Program to Run Existing Workfile Data
Posted: Thu Aug 09, 2012 8:28 am
by EViews Esther
Can you see your workfile with your dataset of interest?
Posted: Thu Aug 09, 2012 8:37 am
Copy and paste your program (or at least the offending part) here.
Posted: Thu Aug 09, 2012 8:38 am
by bjonyou
Yes I have access to my worfile and dataset. I just can't get the program to run or link to it. At least I think thats the problem.
I dont know if the problem is occuring because I did something wrong when I created a new program or saved it to the wrong destination or what.
Posted: Thu Aug 09, 2012 8:39 am
by bjonyou
I grabbed this code from something you wrote or helped someone with.
'create a workfile
junb1_monthly_data.wf1 q 1930 2014
'create a dependent variable
series cons_stap_pe_yoy = nrnd
'create 3 series
series cpi_yoy = nrnd
series avg_hrly_ernings_yoy = nrnd
series savin_rate_yoy = nrnd
%regs = "cpi_yoy avg_hrly_ernings_yoy savin_rate_yoy"
!L = @wcount(%regs)
'create vector to store r-squares, AICs, BICs
vector(2^!L) r2s
vector(2^!L) aics
vector(2^!L) bics
svector(2^!L) specs
'create empty equation to be used inside the loop
equation eq
'1. Make an index vector which contains either 0 or 1 (Convert2Binary)
'2. drop x if index=0, otherwise take x
!rowcounter=1 'counter of how many equations we have run
for !i = 0 to (2^!L)-1
vector(!L) index
!temp= !i
call Convert2Binary(index, !temp)
%xs = ""
for !j = 1 to !L
%reg = @word(%regs,!j)
if index(!j)==1 then
%xs = %xs + %reg + " "
endif
eq.ls y c {%xs}
r2s(!rowcounter) = eq.@r2
aics(!rowcounter) = eq.@aic
bics(!rowcounter) = eq.@schwarz
specs(!rowcounter) = eq.@spec
!rowcounter = !rowcounter+1
d(noerr) index
subroutine local Convert2Binary(vector out, scalar N)
if N<0 then
stop
return
endif
!i = @rows(out)
while N > 1
!a = @floor(N/2)
out(!i) = N-2*!a
!i = !i - 1
N = !a
wend
out(!i) = N
endsub
Posted: Thu Aug 09, 2012 8:42 am
by EViews Esther
'create a workfile
wfcreate junb1_monthly_data.wf1 q 1930 2014
You're missing part of the first line. You need a create command in there.
Posted: Thu Aug 09, 2012 8:54 am
by bjonyou
You guys are GREAT! I may have more questions but THANK YOU!
Posted: Thu Aug 09, 2012 9:36 am
by bjonyou
I need some more help again guys.
I'm trying to combine two programs you have offered
1) Run lagging regressions through an interval (-12 to 12) and provide the lowest AIC (or best fitting model)
2) Store the AIC, R2, etc. in a matrix or vector.
So I essentially combined two different programs together and although it works fine, the AIC output is only storing two outputs and I cannot even tell which period the outputs are for.
The end goal is that I would like to see something like this:
-12 1.02
-11 1.01
-10 1.00
-9 .99
-8 .98
-7 .97
-6 .96
and then I would pick (-6) as it is the lowest AIC. Can you please help? Here is my code:
'create a workfile
'create a variable
equation eq
'variable to store the minimum AIC. Initialise it to a large number
!aic = 99999999
'variable saying how many lags to go up to
!maxlags = 12
'Variable to store the "best" number of lags
!bestlag = 0
'set sample to be the !maxlag'th value onwards
smpl @first+!maxlags @last
for !i=1 to !maxlags
eq.ls cons_stap_pe_yoy c avg_hrly_ernings_yoy(-12 to -!i) 'run regression of Y on a constant and lagged values of itself up to the iTH lag.
if eq.@aic < !aic then
!bestlag = !i 'if this lag specification has the best AIC, then store this lag as !bestlag.
!aic = eq.@aic
endif
show eq.ls cons_stap_pe_yoy c avg_hrly_ernings_yoy(12 to -!bestlag)
'reset sample
smpl @all
%regs = "avg_hrly_ernings_yoy"
!L = @wcount(%regs)
vector(2^!L) r2s
vector(2^!L) aics
vector(2^!L) bics
svector(2^!L) specs
equation eq
vector(!L) index
!temp= !i
%xs = ""
for !j = 1 to !L
endif
eq.ls cons_stap_pe_yoy c {%xs}
d(noerr) index
if N<0 then
stop
return
endif
!i = @rows(out)
while N > 1
!a = @floor(N/2)
out(!i) = N-2*!a
!i = !i - 1
N = !a
wend
out(!i) = N
endsub
Posted: Thu Aug 09, 2012 11:02 am
At some point you are going to have to debug these yourself, but...
!L = 1
This is why you are only getting 2 values. Your loop goes from 0 to 1.
