Hello All,
This is probably a very basic question but I am new to EViews and have no coding experience. I have been running regression and have all my dependent and independent variables set up in a workfile. However, I just created and tried to run a program to alleviate the repetition but I'm getting an error message that states:
Workfile_Data is not defined in "DO_Workfile_Data.WF1d Q 1930 2014".
I have no clue what this means an what I'm doing wrong. Can anyone help me?
Help Needed to Get Program to Run Existing Workfile Data
EViews Esther
Re: Help Needed to Get Program to Run Existing Workfile Data
Can you see your workfile with your dataset of interest?
Copy and paste your program (or at least the offending part) here.
Yes I have access to my worfile and dataset. I just can't get the program to run or link to it. At least I think thats the problem.
I dont know if the problem is occuring because I did something wrong when I created a new program or saved it to the wrong destination or what.
I grabbed this code from something you wrote or helped someone with.
'create a workfile
junb1_monthly_data.wf1 q 1930 2014
'create a dependent variable
series cons_stap_pe_yoy = nrnd
'create 3 series
series cpi_yoy = nrnd
series avg_hrly_ernings_yoy = nrnd
series savin_rate_yoy = nrnd
%regs = "cpi_yoy avg_hrly_ernings_yoy savin_rate_yoy"
!L = @wcount(%regs)
'create vector to store r-squares, AICs, BICs
vector(2^!L) r2s
vector(2^!L) aics
vector(2^!L) bics
svector(2^!L) specs
'create empty equation to be used inside the loop
equation eq
'1. Make an index vector which contains either 0 or 1 (Convert2Binary)
'2. drop x if index=0, otherwise take x
!rowcounter=1 'counter of how many equations we have run
for !i = 0 to (2^!L)-1
vector(!L) index
!temp= !i
call Convert2Binary(index, !temp)
%xs = ""
for !j = 1 to !L
%reg = @word(%regs,!j)
if index(!j)==1 then
%xs = %xs + %reg + " "
endif
eq.ls y c {%xs}
r2s(!rowcounter) = eq.@r2
aics(!rowcounter) = eq.@aic
bics(!rowcounter) = eq.@schwarz
specs(!rowcounter) = eq.@spec
!rowcounter = !rowcounter+1
d(noerr) index
subroutine local Convert2Binary(vector out, scalar N)
if N<0 then
stop
return
endif
!i = @rows(out)
while N > 1
!a = @floor(N/2)
out(!i) = N-2*!a
!i = !i - 1
N = !a
wend
out(!i) = N
endsub
EViews Esther
'create a workfile
wfcreate junb1_monthly_data.wf1 q 1930 2014
You're missing part of the first line. You need a create command in there.
You guys are GREAT! I may have more questions but THANK YOU!
I need some more help again guys.
I'm trying to combine two programs you have offered
1) Run lagging regressions through an interval (-12 to 12) and provide the lowest AIC (or best fitting model)
2) Store the AIC, R2, etc. in a matrix or vector.
So I essentially combined two different programs together and although it works fine, the AIC output is only storing two outputs and I cannot even tell which period the outputs are for.
The end goal is that I would like to see something like this:
-12 1.02
-11 1.01
-10 1.00
-9 .99
-8 .98
-7 .97
-6 .96
and then I would pick (-6) as it is the lowest AIC. Can you please help? Here is my code:
-12 1.02
-11 1.01
-10 1.00
-9 .99
-8 .98
-7 .97
-6 .96
'create a workfile
'create a variable
equation eq
'variable to store the minimum AIC. Initialise it to a large number
!aic = 99999999
'variable saying how many lags to go up to
!maxlags = 12
'Variable to store the "best" number of lags
!bestlag = 0
'set sample to be the !maxlag'th value onwards
smpl @first+!maxlags @last
for !i=1 to !maxlags
eq.ls cons_stap_pe_yoy c avg_hrly_ernings_yoy(-12 to -!i) 'run regression of Y on a constant and lagged values of itself up to the iTH lag.
if eq.@aic < !aic then
!bestlag = !i 'if this lag specification has the best AIC, then store this lag as !bestlag.
!aic = eq.@aic
endif
show eq.ls cons_stap_pe_yoy c avg_hrly_ernings_yoy(12 to -!bestlag)
'reset sample
smpl @all
%regs = "avg_hrly_ernings_yoy"
!L = @wcount(%regs)
vector(2^!L) r2s
vector(2^!L) aics
vector(2^!L) bics
svector(2^!L) specs
equation eq
vector(!L) index
!temp= !i
%xs = ""
for !j = 1 to !L
endif
eq.ls cons_stap_pe_yoy c {%xs}
d(noerr) index
if N<0 then
stop
return
endif
!i = @rows(out)
while N > 1
!a = @floor(N/2)
out(!i) = N-2*!a
!i = !i - 1
N = !a
wend
out(!i) = N
endsub
At some point you are going to have to debug these yourself, but...
!L = 1
This is why you are only getting 2 values. Your loop goes from 0 to 1.
!L = 1
