Can I display the result automaticly with star?
I mean the coefficient is 1% level significant, there will be *** behaind it, 5% level, "**" behind/
such as Coefficient 2.342 *** means it significant at 1% level.
Result display
Re: Result display
There's nothing built in to do it.
You could freeze the equation output into a table, and then add the * yourself manually.
Or you could write a program that does it for you. The SignifCoefs add-in does something similar, but it shades based on colour, rather than adding an *. If you're comfortable with EViews programming, taking a look at the source code and modifying it to do * shouldn't be too hard.
