Annuallized Boxplots
bsinnott1
Postby bsinnott1 » Fri Aug 03, 2012 12:14 pm
Hi there,
I am using a simple moving window rolling correlation of time series data and i would like to know if I can plot the outputs from this data with annuallized boxplots inorder to get a sense of the shift in correlation over time. Any help with this matter would be extremely appreciated
Regards.
Re: Annuallized Boxplots
Postby EViews Glenn » Fri Aug 03, 2012 2:37 pm
Can you be a bit more specific about what you want? I'm afraid I can't quite visualize what you want to do.
bsinnott1
Postby bsinnott1 » Fri Aug 03, 2012 3:01 pm
I am currently working with daily financial data and instead of having one boxplot for all the results of the moving window correlation I would like to have individual boxplots on the same graph but grouped annually to express the change in the relationship through time.
Postby EViews Glenn » Fri Aug 03, 2012 4:27 pm
Open the series of interest. Click on View/Graph... to display the Graph Options dialog,
(1) Click on Basic Type in the Graph Type node in the tree on the left.
Under Graph Type General: choose Categorical graph
Under Graph Type Specific: choose Boxplot
On the right side under Factors, put @YEAR in the Within graph edit field.
(2) Click on Categorical options in the Graph Type node in the tree on the left
Select the @YEAR factor in the Selected Factor listbox
Change the Category Labels/Contents: combo on the right to Factor value only
Click on OK.
