eviews 7
Running the same program on different machines sometimes produces an error message on one machine and not the other.
After estimating equation with OLS, my next line is freeze(outcome)eq1.ls
Sometimes I get a freeze(outcome) already exists message.
It's easy to fix by either making the freeze line on or off, but was wondering if this might be due to a different defaults setting on each machine.
default settings
default settings
It probably depends on whether an object called "outcome" already exists or not, rather than the machine it is run on.
