Page 1 of 3
simple OLS regression- F-statistic is not reported
Posted: Wed Aug 01, 2012 1:00 pm
by gobbble
I have the problem that at the very basic OLS regression of a return variable against its first lag no F-statistic is reported! What can be the problem and how can I get the f statistic and probability. The regression looks like "r(-1) c r"
edit: I am using eviews 7
Posted: Wed Aug 01, 2012 2:23 pm
That's a regression of lagged r on r, not the other way around.
Past that you may want to post your output.
Re: simple OLS regression- F-statistic is not reported
Posted: Thu Aug 02, 2012 1:01 am
by gobbble
here it comes. Regards
Posted: Thu Aug 02, 2012 6:09 am
Something's really, really wrong as you also have a negative R-sqr. I think you've hit a bug. The EViews folks are going to want to know the version and build date of your copy of EViews (Help/About).
Posted: Thu Aug 02, 2012 9:15 am
by gobbble
thanks. I have eviews 7 standard edition Jan 7 2010 build.
By the way, when I regress the other way around, everything turns out fine...
Posted: Thu Aug 02, 2012 9:17 am
You should probably push the update button, since your copy is more than two years out of date. If convenient, it would also be helpful if you posted your EViews workfile.
Posted: Thu Aug 02, 2012 9:19 am
You should update to the latest version, by running the upgrade installer.
http://eviews.com/download/download.html
Posted: Thu Aug 02, 2012 9:47 am
I was waiting to see the output before I nosed in on this one, but so far as I can see, the F-statistic is always reported in this setting in the shipping version of EViews.
Posted: Thu Aug 02, 2012 12:20 pm
by gobbble
unfortunately I cannot uldate it, asI use the license of my university. I have admin rights to update it...
Posted: Thu Aug 02, 2012 12:21 pm
Post your workfile, so we can check it has been fixed in the latest version for you.
Posted: Fri Aug 03, 2012 3:29 am
by gobbble
here is the workfile
Posted: Fri Aug 03, 2012 7:07 am
I can verify that the bug has not been fixed.
So that you can get on about your work, I have done the following.
series rlag=r(-1) ls rlag c r
I've posted the results for you, but I'm 99% certain that you want
ls r c rlag
instead.
Posted: Fri Aug 03, 2012 9:55 am
Thanks for posting the workfile gobble. That helps a great deal.
That's a good suggestion startz and the one that I've used to verify the issue.
I'll have a fix posted shortly.
[edit: it's up]
Posted: Fri Aug 03, 2012 12:02 pm
A fix has been put into the main code base. Please look for the update shortly. I'll try to get them to get it out today.
Posted: Sat Aug 04, 2012 1:41 am
by gobbble
thanks for your help!
