underdispersion
Univ_Aveiro_util
underdispersion
Postby Univ_Aveiro_util » Wed Jul 25, 2012 7:55 am
Someone could help me to correct underdispersion in Poisson estimation?
I tried to do the Negative Binomial (QLM), but when I enter the fixed variance parameter (which is negative in my case) the estimation results says that the QML parameter used in estimation is 1 (not -0.01907 that I enter)...
Thank you for your help.
Re: underdispersion
Postby EViews Glenn » Thu Jul 26, 2012 11:26 am
The negative binomial parameterization we use only allows for overdispersion. What you can do is to estimate with a Poisson and use GLM standard errors which should be valid given underdispersion. The Huber-White standard errors should also be robust to underdispersion.
Univ_Aveiro_util
Re: underdispersion
Postby Univ_Aveiro_util » Mon Jul 30, 2012 8:00 am
Thank you very much for your reply. Could you, please, explain me how i should do that in Eviews?
- In the equation estimation panel for Poisson (integer count), in options, should i select Robust Covariances GLM instead of Huber-White? Is it enough?
Thank you.
Re: underdispersion
Postby EViews Glenn » Mon Jul 30, 2012 9:52 am
Yes. Either should be robust to underdispersion.
