conversion of alpha series to numeric series
tktiong
Postby tktiong » Thu Apr 02, 2009 9:36 pm
hi. actually i am havin a bit of problem with alpha series.I am supposed to do a regression on a set of values.and the data i imported from excel are all in numeric form..but 2 sets of data after i import into eveiws it became alpha series and could not be regressed with the other datasets.so is there any way to rectify it or how could i convert alpha series into numeric series?Thanks
Re: conversion of alpha series to numeric series
Postby EViews Gareth » Thu Apr 02, 2009 10:10 pm
You can use the @val function to convert from a alpha to a numerical series.
However if EViews has read it in as an alpha, its likely that there is something odd/strange about the data, and using @val might not work all that well.
tktiong
Postby tktiong » Fri Apr 03, 2009 12:50 am
erm..now i change my data and it came up with en error displaying'near singular matrix'..any recommendations to remedy it ?
Postby startz » Fri Apr 03, 2009 3:56 am
You've entered a redundant series. Most often, this comes from using a complete set of dummies plus a constant.
