Dynamic Panel Regression GMM
tinfah
Postby tinfah » Wed Jul 04, 2012 5:42 am
Like the many who have attempted to estimate their panel data using Dynamic Panel Data Wizard on first difference GMM, I run into the problem of "the number of instruments is greater than the number of observations". I worked with a panel data file of 1,456 observations (19601 20114x7) but I still get into this problem. Is it because my N<T (ie cross section data is smaller time series observations)? In the series that you have in abond_pan.wf1, you have 1031 observations (1976 1984x140), which makes the N>T.
Re: Dynamic Panel Regression GMM
Postby EViews Gareth » Wed Jul 04, 2012 9:59 am
It depends on which options you choose when doing DPD. But if you choose to have instruments that increase with T, then you generally need N>T.
tinfah
Postby tinfah » Wed Jul 04, 2012 6:27 pm
Dear Gareth
That is true, but if we I want to use a difference option as in Arellano bond estimation, I run into this problem of the number of instruments is greater than the number of observations.
saba
Postby saba » Wed Jul 11, 2012 7:22 am
dear
i am also encountered with same problem.. kindly help me.... ur help will be very valuable for me. tell me what is the meaning of this message that "no. of instruments are greater than the number of observation" i am a new user don't know much about the mechanics of GMM kindly tell me in simple way.... i shall be extremely thankful to you
tinfah
Postby tinfah » Wed Jul 11, 2012 5:22 pm
One option is to increase the number of cross section data or reduce the time series data. Run it and see how it goes. Another is not to use the difference option in the GMM specification box. It works well if you don't use the difference option.
saba
Postby saba » Thu Jul 12, 2012 10:50 am
ok thanks will try it and then let u knw
amana24
Postby amana24 » Wed Sep 26, 2012 3:46 am
Dear Tinfah,
I have slightly the same problem. I want to test the following regression with cross section fixed effects:
s = s sr rat
All the independent variables have 5 lags
When I enter the following instrument in the wizard:
@dyn(_2y,-5)
I still get the error message :
order condition violated - insuffencient instruments
What kind of instrument should I enter?
Regards,
Amana
amana24
Postby amana24 » Wed Sep 26, 2012 5:47 am
s stand for yield
rat stands for rating
and sr stands for stock exchange index (instrument variable)
amana24
Postby amana24 » Wed Sep 26, 2012 7:10 am
After completing the wizard
I get the following list for instruments:
@dyn(_2y,-2) c rat(-1) rat(-2) rat(-3) rat(-4) rat(-5) sr(-1) sr(-2) sr(-3) sr(-4) sr(-5)
nozkan23
Postby nozkan23 » Sun May 05, 2013 6:39 am
Can anybody show me how to apply GMM producure with Newey and West (1987) correction for autocorrelation for one lag? Thank you.
