rndseed
Posted: Wed Jun 27, 2012 6:24 am
I have a couple of questions about rndseed.
First if the rndseed is not set, then I assume that the time of day is used as the seed. Is the time used in thousandths of a second? I'm running several jobs simultaneously where that would be important.
Second, once the rndseed is set to some scalar, is it possible to reset it back to time of day?
This is important to be able to run multiple jobs simultaneously where each job runs repeatable simulations, but then use utility programs that require unique random numbers between the multiple jobs. (Did I make that confusing enough?)
Thanks,
Tim
Thanks,
Tim
