I have a couple of questions about rndseed.
First if the rndseed is not set, then I assume that the time of day is used as the seed. Is the time used in thousandths of a second? I'm running several jobs simultaneously where that would be important.
Second, once the rndseed is set to some scalar, is it possible to reset it back to time of day?
This is important to be able to run multiple jobs simultaneously where each job runs repeatable simulations, but then use utility programs that require unique random numbers between the multiple jobs. (Did I make that confusing enough?)
Thanks,
Tim
rndseed
Re: rndseed
Is is based on time of day, yes.
I do not believe there is a way to unseed the RNG. However you could always generate a random integer, then set the rndseed, then, when you need it off, set it again using the random integer you created.
Re: rndseed
Gareth's suggestion is a fine one, but we probably should offer a way to reset to clock. We'll put it on the list of things to look at.
Re: rndseed
Thanks Gareth and Glenn for your replies.
The problem with Garath's suggestion is I have an addin that is used by everyone to access our databases. This addin uses files to store the temporary data before reading and writing into eviews. The filenames have to have unique names so there aren't any conflicts when someone is running multiple jobs. The problem with using the RNG is someones program might have set the rndseed before calling the addin, therefore making the filenames not unique.
Another solution is to get the process id to use as part of the filename. EViews doesn't appear to have easy access to the process id, so I'll have to spawn a shell process and then parse the output. :(
In the Perl language the process id is $$. Something like that would be very nice.
Do you guys have any better ideas?
Thanks,
Tim
Thanks,
Tim
Re: rndseed
Shell to DOS random number generator:
That gets you outside of EViews' RNG, and thus outside of RNDSEED.
shell(out=t) echo %random%
