the data is too much to be operated??
Posted: Tue Jun 26, 2012 1:41 am
by fdmyang
I'm facing a big problem and I'm really confused by this:
I put around 151,000 data and system told me that the test could not be operated because there are so many data, is this really?? If yes, so how many data it could be??
Thanks!
Posted: Tue Jun 26, 2012 7:54 am
by startz
You need to be explicit about what you did and what version you're using.
Re: the data is too much to be operated??
Posted: Wed Jun 27, 2012 8:57 pm
by fdmyang
Ok, thanks for your reply firstly.
I'm using EViews6. I wanna make Unit root test, cointegration test, Husman test, and OLS test. But only the Unit root test could be processed and I have been told that too much data to process while I was tring to run others....How can I do?
Posted: Wed Jun 27, 2012 9:05 pm
by fdmyang
it said:"Matrix size error: too many parameters for default coefficient vector ". You also plz read attachment I posted here. Thanks.
Posted: Wed Jun 27, 2012 10:12 pm
by startz
What command lead to the error that you show?
Posted: Fri Jun 29, 2012 2:33 am
by fdmyang
pool/"Cointegration Test". Is it possible i send the workfile to you by email so that you can check the detail??
Posted: Fri Jun 29, 2012 2:37 am
by fdmyang
Meanwhile, my data is "unbalance panel data", but there are only three options for selecting in workfile creation which are "dataed- regular frequency", "Unstructed/undated", and"balanced panel data", so which one I should to select?? thanks!
Posted: Fri Jun 29, 2012 5:58 am
by startz
Be sure your copy of EViews is uptodate. Past that you may need help from the EViews staff.
Posted: Sat Jun 30, 2012 8:28 am
by fdmyang
sure...i 'll install eviews 7 for a testing...but still be confused by the problem:
Posted: Sat Jun 30, 2012 1:23 pm
You cannot create an unbalanced panel. You can only open one.
Posted: Sun Jul 01, 2012 8:28 pm
by fdmyang
Thanks Gareth, so which one i should select among the three while I create workfile?? dated-frequency??
