Can Eviews create Johansen cointegration test with I(2) series? Can Eviews create Multicointegration test e. g. series: I(2), I(2), I(1). Thank you.
I used to Eviews 7.2 Standard Edition - May 29. 2012 build.
Johansen Cointegration Test-VECM-I(2) and Multicointegration
josef.hodek
Re: Johansen Cointegration Test-VECM-I(2) and Multicointegra
having the exact same problem right now, 4 of my variables are I(2) and one is I(0). My supervisor is absolutely useless she said that I could still run a johansen test and it was fine but I have just discovered that is not the case. Did you find a solution to the issue? I would really really appreciate the help.
cheers
cheers
aacasiobuk
