Runnig multiple equations without stopping
jmontechiari
Postby jmontechiari » Fri Jun 01, 2012 8:22 am
I have a table with 63 equations to run.
I have already done the program to execute all the equations and it's working well.
When I achieve the equation 9, the program gives me a message about "OVERFLOW" or another problem like that because of my initial solution and stop to execute the others equations.
I would like to know how I can avoid the message and keep running the other equations.
Thanks,
Jorge Montechiari
Re: Runnig multiple equations without stopping
Postby EViews Gareth » Fri Jun 01, 2012 8:27 am
Generally you can set the maximum number of errors in the program to a high amount (either use the setmaxerrs command, or use the option on the run dialog). I'm not sure if that will work with an overflow error though. Try it.
jmontechiari
Postby jmontechiari » Fri Jun 01, 2012 9:01 am
I didn't know it was so simple.
rs
Thanks.
