Hi guys. but I have another problem. As you can see in attached workfile I have two system specification called gmmmccsgg05 and gmmmcnsgg05, I would like to IV Diagnostics Tests as well as GMM breakpoint tests, the manual says that if you choose View there should be options including IV Diagnostics tests and Breakpoint test, but when I click on View in either of the system specification I can't see those options there.
I also tried include the following statement in system specification:
breaktest 1974q1 1979q2 1990q3
But it says this command is unknown.
Can you please help me with this and let me know how can I do different types of breakpoint test stated in manuals, i.e. Andrews-Fair (1988) Wald Statistics, Andrews-Fair LR-type statistics and Hall and Sen (1999) O-statistics.
Thanks a lot for your help in advance.
GMM Breakpoint test and IV Diagnostics
somaiiehmr
- gmm5410.wf1
- (50.6 KiB) Downloaded 244 times
Re: GMM Breakpoint test and IV Diagnostics
Those tests are not supported for systems of equations, only single equation estimation.
