auto placing variable value in chart
vogelh
Postby vogelh » Mon May 21, 2012 2:34 pm
Using Eviews 7.2.
I've defined !probcutoff=0.15
this is my name for a given p-value.
Is there a simple way to automatically place this as a string or otherwise as part of or into chart?
thanks.
Re: auto placing variable value in chart
Postby EViews Gareth » Mon May 21, 2012 2:41 pm
Use chart.addtext
vogelh
Postby vogelh » Wed May 23, 2012 4:57 pm
Sorry to bother again. Still having difficulty implementing instructions.
I want to add !probcutoff = 0.15 with
string probval ="pval="
to the line graph generated as shown below.
What would you recommend to get the !probcutoff value into the graph?
thanks
My program works fine in doing the following:
smpl @first @first+!length-2*!ssize
if !v=1 then line wabsigraphts
endif
if !v=2 then line wacsigraphts
endif
thanks.
Postby EViews Gareth » Wed May 23, 2012 7:04 pm
Use the:
freeze(graphname) series.line
method of generating the graph.
