I'd like to write a program that updates graphs in 2 or more existing workfiles pages. I've already searched on EViews Command & Programming, but I've got no clue! Is it possible to do it or do I have to write one program for each workfile?
I'm using EViews 7.1.
Thanks for your help! :D
Changing WF pages in Programming
Re: Changing WF pages in Programming
I think this should do it for you...
Pageselect
Make the specified page in the default workfile the active page.
Syntax
pageselect pgname
where pgname is the name of a page in the default workfile.
Examples
pageselect page2
changes the active page to PAGE2.
Cross-references
See also wfselect.
Pageselect
Syntax
pageselect pgname
Examples
pageselect page2
Cross-references
See also wfselect.
gio.ortolani
Glenn,
thank you so much! It has perfectly worked! ;)
More sophisticated issue, however on the same area.
Is there any posibility for Eviews6 programs to navigate between pages without hard coded page names. I would like to have a program, which gets series name from workfile and creates trendline from x12 seasonal adjustment on different samples, like in following code:
Additionaly i would like to store this bunch of series on a different workfile page. I know the name of destination page, just like that:
Unfortunately i do not know how to come back to the source page. Is there any command which could help me (e.g. transfering page name to string)?
I am working on EVIEWS 6
EDIT: I know i can pass the page name as a 2nd argument of program, still come on it is inconvenient.
!forecastPeriods= @obs({%0})
%prefix = "x12_"
FOR !i = 0 TO !forecastPeriods/2
SMPL @first @last - !i
%name = %prefix + @str(!i)
{%0}.x12(mode="a", save="d10 d12") {%name}
NEXT
pagecreate(byid, page="x12_seas") @dateI am working on EVIEWS 6
Not in EViews 6.
