WfOpen ASCII file
paues
WfOpen ASCII file
Postby paues » Mon Apr 23, 2012 7:12 am
I am trying to open the attached ASCII file using the command wfopen. However, I cannot figure out what arguments I should provide for EViews not to show the dialog box "Text Read - Step 1 of 1". Is it possible? What I have now is
wfopen(type=text) AKU_SR_text.txt colhead=1 delim=tab
AKU_SR_text.txt
Monthly data
(1.22 MiB) Downloaded 343 times
WfOpen ASCII file
Postby EViews Gareth » Mon Apr 23, 2012 8:43 am
In a program, or via the command line?
paues
Re: WfOpen ASCII file
Postby paues » Mon Apr 23, 2012 2:20 pm
I am looking to use it in a program. But I thought the two equivalent - aren't they? - and have as of yet only tried via the command prompt.
paues
Postby paues » Tue Apr 24, 2012 12:00 am
I have now tried the same command (with the argument specified in my first post) in a program. And it gives the desired result. What extra arguments need to be added to achieve the same behavior from the command prompt?
WfOpen ASCII file
Postby EViews Gareth » Tue Apr 24, 2012 12:28 am
Some (many) commands behave differently when used in the command window compared to in a program, most often with respect to the opening of dialogs. There is no way around it.
