about cointegration command: coint(method=eg)
lexjl5
Postby lexjl5 » Wed Apr 18, 2012 4:47 am
I have one problem about the cointegration command for engle-granger cointegration.
As I have a large pool of price time series and I want to calculate the ADF t-value for each pair-wise in the data-set, I use the command coint(method=eg) in the loop. I found, for most pair-wise, the ADF t-value got from the command is different from the mouse click procedure. I attached two price time series as one sample.
My command is : group g log(_1a) log(_2a)
g.coint(method=eg)
for mouse click: Quick--> Equaiton Estimation--> cointreg --> Dynamic OLS (none) --> Engle-Granger cointegration test
I found both the t-value and the observation in the intermediate results are different.
Why are they different? Or how to write the programme to run as the mouse click procedure.
Your assistance is highly appreciated
many thanks for your help
best wishes
Jianan Li
data sample.xlsx
two time series log(Price)
(33.38 KiB) Downloaded 482 times
Re: about cointegration command: coint(method=eg)
Postby EViews Glenn » Wed Apr 18, 2012 11:23 am
Are the lags used the same? The EG uses a default of 1.
