Searching for parts of a string
paues
Postby paues » Wed Apr 18, 2012 1:44 am
Is there any built-in function to search for parts of a string? If we, for example, have the string "fivewordswrittenasone" and want to search to see if the substring "words" can be found therein? That is, I am looking for a function that relates to @wfind as @mid relates to @wmid and thus would return the same as the code below.
%str="fivewordswrittenasone" %sub="words" !strlen=@len(%str) !sublen=@len(%sub) for !i=1 to !strlen-!sublen+1 %piece=@mid(%str,!i,!sublen) if %piece=%sub then %return=%piece exitloop endif next
trubador
Did you use forum search?
Re: Searching for parts of a string
Postby trubador » Wed Apr 18, 2012 2:46 am
I am not sure if this is what you want, but you can try the following:
!return = @instr(%str,%sub)
which will yield 5. If %sub had not existed in the base string %str, then it would have returned zero.
The following will give you the same result as your code:
%return = @mid(%str,@instr(%str,%sub),@length(%sub))
paues
Postby paues » Wed Apr 18, 2012 3:22 am
That was exactly what I was looking for :-) Thank you!
