I'm running a vecm and I would like to know if is possible to get the tstat of the coefficients (something like @tstat but I don't know how to use it for a vecm).
thank you very much if you can help me...
coef in vecm
Re: coef in vecm
They aren't stored with the VAR/VEC object, so you can't retrieve them. However the coefficients are stored in @coefmat and the standard errors are in @coefse. You should be able to calculate the t-stats from those two.
Re: coef in vecm
Thank you very much for the response ! It is exactly what I needed.
have a good day.
have a good day.
Re: coef in vecm
Where are stored the coefficients of a dols equation ? I've tried @coefmat but it dosen't seem to work.
thank you
thank you
coef in vecm
@coefs
