About Calculating Quintiles
kinon902003
Postby kinon902003 » Mon Mar 19, 2012 2:12 am
I am writing programmes to calculate quintiles for a matrix. I found that @quantile maybe useful.
May I confirm that the following command can calculate 20% quintile with the name "quintile_1"?
scalar quintile_1 = @quantile(xxx, 0.2)
xxx is the name of the matrix
I am not sure what I have done is correct because the answer is not the same when I calculate it in Excel by the function "percentile".
Thank you very much for your help!
Re: About Calculating Quintiles
Postby EViews Gareth » Mon Mar 19, 2012 7:50 am
Yes, that's right, although note that the quantile will be calculated over every element in the matrix, not just the first column or row (as is the case with some other programs).
Postby EViews Glenn » Mon Mar 19, 2012 10:46 am
Note also that there are various options for defining the computation of the quantiles. The default may not line up with what Excel does, but there may be an option that will do so.
kinon902003
Postby kinon902003 » Mon Mar 19, 2012 8:49 pm
Thank you so much for your confirmation.
