Import mixed data
PMaier
Import mixed data
Postby PMaier » Mon Mar 12, 2012 2:42 pm
I could use some help on importing a somewhat complex CSV file. The file is structured as follows:
INDX_NM INDX_DESC SCE_NM PERIOD VALUE
UST 3M US Treasury Bill (3M) TDA_U1 6/1/2004 1.088
UST 3M US Treasury Bill (3M) TDA_U1 9/1/2004 1.5037
UST 3M US Treasury Bill (3M) TDA_U1 12/1/2004 2.0338
UST 3M US Treasury Bill (3M) TDA_U1 3/1/2005 2.5748
UST 10Y US Treasury Note (10Y) TDA_U1 6/1/2004 4.5864
UST 10Y US Treasury Note (10Y) TDA_U1 9/1/2004 4.3082
UST 10Y US Treasury Note (10Y) TDA_U1 12/1/2004 4.1742
UST 10Y US Treasury Note (10Y) TDA_U1 3/1/2005 4.2996
FFTGTAVG Average Target Federal TDA_U1 6/1/2004 1
FFTGTAVG Average Target Federal TDA_U1 9/1/2004 1.413
FFTGTAVG Average Target Federal TDA_U1 12/1/2004 1.9348
FFTGTAVG Average Target Federal TDA_U1 3/1/2005 2.4333
UST 3M US Treasury Bill (3M) TDA_U2 6/1/2004 1.088
UST 3M US Treasury Bill (3M) TDA_U2 9/1/2004 1.5037
UST 3M US Treasury Bill (3M) TDA_U2 12/1/2004 2.0338
UST 3M US Treasury Bill (3M) TDA_U2 3/1/2005 2.5748
UST 10Y US Treasury Note (10Y) TDA_U2 6/1/2004 4.5864
UST 10Y US Treasury Note (10Y) TDA_U2 9/1/2004 4.3082
UST 10Y US Treasury Note (10Y) TDA_U2 12/1/2004 4.1742
UST 10Y US Treasury Note (10Y) TDA_U2 3/1/2005 4.2996
FFTGTAVG Average Target Federal TDA_U2 6/1/2004 1
FFTGTAVG Average Target Federal TDA_U2 9/1/2004 1.413
FFTGTAVG Average Target Federal TDA_U2 12/1/2004 1.9348
FFTGTAVG Average Target Federal TDA_U2 3/1/2005 2.4333
The complication is that the entire file is pretty big, but I only need parts of it. For instance, I'm only interested in the first two observations (2004Q2+Q3), and I would like to filter such that I only get FFTGTAVG and discard, say, UST 10Y.
I've been experimenting with the import file, but I have to say that I haven't been terribly successful. For instance, if my file has a date range of, say, 2004Q2-2004Q3, then the command
import %file @freq q 2004q2
reads in data for the first variable (UST 3M), not for all of them. Also, in an ideal world, I could directly use some of the information in the table to name the variables, such as use sce_nm as part of the variable name ("var_{%sce_nm}").
Any help would be appreciated,
Philipp
Re: Import mixed data
Postby EViews Gareth » Mon Mar 12, 2012 2:55 pm
You could use the @smpl argument to filter which observations to import. Something like:
@smpl 2004q2 2004q3 if indx_nm = "FFTGTAVG"
PMaier
Postby PMaier » Tue Mar 13, 2012 4:47 am
Unfortunately - it doesn't seem to work.
I uploaded a sample file. When I run the following code:
wfcreate(wf=Test) q 2004 2012 import(resize) "Test.csv" @drop modeler fcst_month @freq q 2004q2 @smpl 2010q1 2012q4 if INDX_NM="FFTGTAVG"
I get the following error:
Error in Sample: INDX_NM is not defined in "IMPORT(TYPE="TEXT")....
Any idea why? If I don't use the smpl if-command, the variable INDX_NM is imported correctly, so it doesn't seem to be the case that Eviews doesn't properly recognize the variable.
Many thanks, Philipp
Test.csv
(272.3 KiB) Downloaded 493 times
Postby EViews Gareth » Tue Mar 13, 2012 8:16 am
Sorry, my bad. Try this:
import(resize) "Test.csv" @drop modeler fcst_month @freq q 2004q2 @smpl 2010q1 2012q4 @selectif INDX_NM="FFTGTAVG"
PMaier
Postby PMaier » Tue Mar 13, 2012 9:08 am
Thanks, Gareth. This works.
One more question:
I will need different parts of the file (different values for "indx_nm", so to speak), and I can loop through them. However, given how large the original file is, it take a really long time to load it every time the loop is executed.
Is there a way I can import the whole file into a matrix or table? I tried matrix.read, but all the string values stay empty. A table would work, I guess, but there doesn't seem to be an import functionality for tables?
Any other thoughts would be appreciated,
Philipp
Postby EViews Gareth » Tue Mar 13, 2012 9:11 am
No. The only way to bring it all in would be to bring it in as a separate page (using pageload), and then copy from the big page to the smaller page.
